[Qgis-user] Re: Help in using Grass plugin to interpolate point	data
    Giovanni Manghi
    giovanni.manghi at faunalia.pt
    Wed Jan  4 05:28:35 PST 2012
In the QGIS GUI it seems it is missing the dropdown to allow select the
column with the values to be interpolated. You can file a ticket about
this, it should be easily fixed.
>From the GRASS shell you must add also the "layer=" parameter, as it is
described in the man page
example
v.surf.bspline input=point_vector raster=interpolate_surface layer=1
column=attrib_column
cheers
-- Giovanni --
On Wed, 2012-01-04 at 05:06 -0800, pieri70 wrote:
> Ok,
> after a conversion to grass vector layer i get an error saying:
> ERROR: Need either 3D vector or layer and column with z values
> The vector layer has a column named ripelite that qgis read as double.
> in Grass the same error
> v.surf.bspline -c input=pippopippo at mapsetprova raster=provaspline
> column=ripelite
> What's the problem?
> Thanks
> Pietro
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Help-in-using-Grass-plugin-to-interpolate-point-data-tp7150158p7150334.html
> Sent from the qgis-user mailing list archive at Nabble.com.
> Qgis-user mailing list
