[Qgis-user] pre-formatting KML output in QGIS or other options
maning sambale
emmanuel.sambale at gmail.com
Sun Jan 8 18:19:31 PST 2012
Not entirely a QGIS question but closely related. I have a data layer
that is regularly updated in QGIS. This layer will then be converted
to KML as an overlay in a static webmap (google or openlayers).
Importing to KML is straightforward in QGIS. (Select Layer,
righy-click "Save as"). However, I want to pre-format the styling of
the KML to:
1. Change KML styling (fill and outline) according to a specified
attribute column in the data.
2. Change display formatting of popup box. I.e. a column for the
popup box name. Other attributes as hyperlinks, bullet points and
image links.
There was a C+ plugin before that do the styling [0]. Is it updated
for qgis 1.7 as a python plugin? Maybe others have some text munging
scripts to edit the kml, care to share?
[0]http://gis-lab.info/qa/qgis2google-eng.html
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
