[Qgis-user] "Combine" multiple lines into one
Matej Mailing
mailing at tam.si
Wed Jan 18 01:10:36 PST 2012
thanks. This ssems to do it, but it expects to select two lines and execute
it for every pair. Our line layer has about 700 lines in it (PostGIS db)
and basically this would take a lot of time to do it by hand ...
The problem could also be that the lines are not exactly one on another, so
some buffered select would be needed.
Matej
2012/1/18 Alexander Bruy <alexander.bruy at gmail.com>
> 2012/1/18 Alexander Bruy <alexander.bruy at gmail.com>:
> > Hi,
> > look at JoinLines plugin from GIS-Lab repository. It can merge
> intersected
> > lines or lines that have common vertex into single line.
> > 2012/1/18 Matej Mailing <mailing at tam.si>:
> >> Hi,
> >> we have a line layer that has some segments where lines are one on
> another
> >> and we need to eliminate those double lines so that in the case where
> there
> >> are multiple lines one on another, to get them combined into one line.
> What
> >> would be the easiest way to achieve this in QGIS?
> > Hope this helps
> > Alexander Bruy
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120118/12347eab/attachment.html>
