[Qgis-user] Atlas plugin - create map books
Vincent Picavet
vincent.ml at oslandia.com
Wed Jan 25 00:48:57 PST 2012
A quick message to point you to a new «Atlas» plugin, which let you
create pdf map books given a layer defining map zones.
The plugin is available in the experimental part of the new plugin
repository.
A few links :
http://www.oslandia.com/tech/?p=1079
http://hub.qgis.org/projects/atlas
http://plugins.qgis.org/plugins/atlas/
I hope it will be useful to you :)
Vincent
