[Qgis-user] PyQgis MapServer Export with Mapserver 6.0.1
Francesc CaƱas
kikocanas at gmail.com
Mon Jan 30 04:37:51 PST 2012
I've created a map file with the PyQgis Mapserver export pluggin but it
doesn't work. They tell me it's cause the plugguin it's for older versions
of mapserver. (I have the 6.0.1)
What changes I have to do in the .map file to makes it work?
Thanks!
Map code:
# Map file created from QGIS project file
C:/Users/Francesc/Documents/Projectes_CAT_wgs.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME "Projectes Auma UTM31"
# Map image size
SIZE 100 100
UNITS dd
EXTENT -9.569062 32.926808 6.763360 44.857479
FONTSET './fonts/fonts.txt'
SYMBOLSET './symbols/symbols.sym'
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
IMAGEMODE RGBA
EXTENSION 'png'
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH 'C:/Users/Francesc/Documents/temp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/C:/Users/Francesc/Documents/temp/'
# WMS server settings
METADATA
'ows_title' 'Projectes Auma UTM31'
'ows_onlineresource'
'http://localhost/cgi-bin/mapserv.exe?map=C:/Users/Francesc/Documents/Projectes_wgs84_v7.map'
'ows_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See
TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
END
LAYER
NAME 'Provincias_wgs84'
TYPE POLYGON
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
DATA 'C:/Users/Francesc/Documents/SHP/Provincias_wgs84.shp'
METADATA
'ows_title' 'Provincias_wgs84'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
WIDTH 0.35
OUTLINECOLOR 0 0 0
END
END
END
LAYER
NAME 'Projectes_UTM31_wgs84'
TYPE POINT
DUMP true
DATA 'C:/Users/Francesc/Documents/SHP/Projectes_UTM31_wgs84.shp'
METADATA
'ows_title' 'Projectes_UTM31_wgs84'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
STYLE
SYMBOL "circle"
SIZE 7.0
OUTLINECOLOR 0 0 0
COLOR 103 132 169
END
END
END
END
View this message in context: http://osgeo-org.1560.n6.nabble.com/PyQgis-MapServer-Export-with-Mapserver-6-0-1-tp4350528p4350528.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
