[Qgis-user] Converting CSV into a database
Gerhardus Geldenhuis
gerhardus.geldenhuis at gmail.com
Mon Jan 30 11:18:55 PST 2012
Cool,
I did all that and it works kind of but I now get:
PySpatiaLite python module is required for QSpatiaLite
I have installed every available Spatialite package:
libspatialite-dev install
libspatialite2 install
libspatialite3 install
spatialite-bin install
Thoughts? Maybe 2 and 3 is clashing? I can try and remove spatialite and
qgis completely again and try a reinstall. I did not remove spatialite when
I did the qgis reinstall.
Regars
On 30 January 2012 19:13, Alex Mandel <tech_dev at wildintellect.com> wrote:
> Add 3rd Party Repos.
> http://www.qgisworkshop.org/html/workshop/python_in_qgis_tutorial1.html
> Then look for the QSpatialite plugin.
> Enjoy,
> Alex
> On 01/30/2012 11:04 AM, Gerhardus Geldenhuis wrote:
> > Ok,
> > Complete removal and re-installation seem to have done the trick.
> > Thank you very much for all the help so far.
> > I can see the correct menus now and the Plugin Installer Plugin is
> > installed and working. However the plugin listings is very limited. Any
> way
> > to get more python plugins listed?
> > This is the repositories I have listed:
> > http://pyqgis.org/repo/official
> > after browsing to that I have now added user contributed. Could this be
> > installed by default perhaps?
> > Regards
> > On 30 January 2012 18:18, Alex Mandel <tech_dev at wildintellect.com>
> wrote:
> >> Gerhardus,
> >> I wonder if something is strange with the main qgis packages. I suggest
> >> trying the packages from Ubuntugis repositories instead, as detailed
> here:
> http://hub.qgis.org/projects/quantum-gis/wiki/Download#Ubuntu-With-updated-dependencies
> >> So try to remove your current install, change your repos, and the update
> >> and install again, making sure to grab the python-qgis too.
> >> Thanks,
> >> Alex
> >> On 01/30/2012 09:18 AM, Gerhardus Geldenhuis wrote:
> >>> Hi Alex,
> >>> The Plugin Installer if that is a plugin itself then it is not listed.
> >>> The keyservers have not been working for a while and that breaks any
> >> other
> >>> updates. Which means I have to deselect any QGIS related updates every
> >> time
> >>> ubuntu updates my laptop.
> >>> This is my listed repositories:
> >>> deb http://qgis.org/debian natty main
> >>> deb-src http://qgis.org/debian natty main
> >>> and I am definitely using natty and have not upgraded my OS.
> >>> Regards
> >>> On 29 January 2012 19:10, Alex Mandel <tech_dev at wildintellect.com>
> >> wrote:
> >>>> Check in the Manage Plugins menu that you have the Plugin Installer
> >>>> enabled.
> >>>> The authentication thing is no big deal sometimes the keyservers just
> >>>> aren't working. As a question of clarification which repository are
> you
> >>>> installing QGIS from?
> >>>> Thanks,
> >>>> Alex
> >>>> On 01/29/2012 04:40 AM, Gerhardus Geldenhuis wrote:
> >>>>> Hi
> >>>>> That installation unfortunately had no effect. Still no python plugin
> >>>> menu
> >>>>> option. In addition I also get the message:
> >>>>> WARNING: The following packages cannot be authenticated!
> >>>>> libqgis1.7.3 python-qgis python-qgis-common
> >>>>> Install these packages without verification [y/N]? y
> >>>>> which I ignored
> >>>>> I ran sudo ldconfig thinking maybe a link somewhere is missing but
> that
> >>>> did
> >>>>> not do the trick either. The packages were installed previously:
> >>>>> Preparing to replace python-qgis 1.4.0+12730-5ubuntu1 (using
> >>>>> .../python-qgis_1.7.3-1~natty1_i386.deb) ...
> >>>>> Unpacking replacement python-qgis ...
> >>>>> Preparing to replace python-qgis-common 1.4.0+12730-5ubuntu1 (using
> >>>>> .../python-qgis-common_1.7.3-1~natty1_all.deb) ...
> >>>>> so maybe there is something else wrong?
> >>>>> Regards
> >>>>> On 28 January 2012 21:46, Alex Mandel <tech_dev at wildintellect.com>
> >>>> wrote:
> >>>>>> A classic problem we really need to tackle better: you're missing
> the
> >>>>>> python-qgis package or maybe the base plugins
> >>>>>> sudo apt-get install python-qgis python-qgis-common
> >>>>>> Give that a try, restart qgis and see if you have python plugin
> >> access.
> >>>>>> Thanks,
> >>>>>> Alex
> >>>>>> On 01/28/2012 01:39 PM, Gerhardus Geldenhuis wrote:
> >>>>>>> Thanks Alex,
> >>>>>>> I only have "Manage Plugins" and "Python Console" on my Plugins
> menu
> >>>> and
> >>>>>> my
> >>>>>>> list of plugins does not contain qspatialite plugin. I am using
> 1.7.0
> >>>> on
> >>>>>>> Ubuntu. I am trying to get the spatialite gui working at the moment
> >> as
> >>>>>> the
> >>>>>>> alternative.
> >>>>>>> Regards
> >>>>>>> http://www.gaia-gis.it
> >>>>>>> On 28 January 2012 21:16, Alex Mandel <tech_dev at wildintellect.com>
> >>>>>> wrote:
> >>>>>>>> On 01/28/2012 01:08 PM, Gerhardus Geldenhuis wrote:
> >>>>>>>>> Hi
> >>>>>>>>> I have spend some time polishing the data I have and it is in csv
> >>>>>>>> format. I
> >>>>>>>>> would like to run queries on it and display a number of custom
> >>>>>> queries's
> >>>>>>>>> data on my map. I thought spatialite would be the answer but I am
> >>>>>>>>> struggling to connect the dots. I first tried to import the csv
> >> file
> >>>>>>>>> directly which worked a treat. I then exported the csv file as a
> >>>> SQLite
> >>>>>>>>> database and tried to add it as Spatialite database, that failed
> >> for
> >>>>>>>>> obvious reasons.
> >>>>>>>>> I then thought that maybe I can directly do queries on the csv
> >>>>>> data.... I
> >>>>>>>>> managed to get a query working on the data and that query now
> >>>> displays
> >>>>>>>>> different coloured dots. However I could not find this query
> again
> >>>> nor
> >>>>>>>> seem
> >>>>>>>>> to be able to change the symbology based on the query type.
> >>>>>>>>> My csv file contain multiple types of points which I would like
> to
> >>>> map
> >>>>>>>> with
> >>>>>>>>> different symbology. Any help would be appreciated. The manual
> >>>> explains
> >>>>>>>> how
> >>>>>>>>> to create a spatialite db but makes no mention of how to get data
> >>>> into
> >>>>>> a
> >>>>>>>>> spatialite db,
> >>>>>>>>> Any help would be greatly appreciated.
> >>>>>>>>> Best Regards
> >>>>>>>> Try the QSpatialite plugin (from Fetch python plugins).
> >>>>>>>> 1. Create an empty spatial database
> >>>>>>>> 2. Connect and use the Upload Tables tab under which you can pick
> >> CSV
> >>>> as
> >>>>>>>> the source.
> >>>>>>>> Alternative method, download the spatialite gui from spatialite
> >>>> website
> >>>>>>>> and use that to import the csv. Once imported QGIS will be able to
> >> see
> >>>>>>>> it, though you may need to create a geometry column and run an
> >> update
> >>>>>>>> query to populate it.
> >>>>>>>> Enjoy,
> >>>>>>>> Alex
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120130/d6ec18f2/attachment.html>
