[Qgis-user] QGIS MSSQL 2008 Data import problem
Noli Sicad nsicad at gmail.com
Mon Jul 9 20:47:50 PDT 2012
Hi Martin,
I think QGIS will only work with MSSQL in Mac OS X and Linux with
iODBC driver/library support in it.
QGIS must be compiled with iODBC driver / library.
I cc:ed you in my post to QGIS developer regarding this issue.
You can probably compiled QGIS with iodbc library yourself.
Here's the new iodbc github:
https://github.com/openlink/iODBC
Noli
On 7/9/12, Martin Tomko <tomkom at unimelb.edu.au> wrote:
> Dear Noli,
> Thanks for the helpful posts.
> I managed to configure iODBC with an OpenLInk driver (not free, using a
> trial licence for the moment) on my Mac. The test connection from the
> iODBC Administrator is established without problem.
> I am however, not able to get the connection established through QGIS. It
> still complains that a driver is not found .To me, this suggests that the
> driver installed and discovered by iODBC is not discovered by QGIS> Is
> there some environmental variable you need to set to make it work, for
> QGIS?
> Thanks,
> Martin
