[Qgis-user] What hardware for QGIS
neil2 at ansergis.net
Thu Jun 7 05:36:46 PDT 2012
Thanks for the replies, very helpful.
Looks like I will be going for Ubuntu VMs for Q-GIS, but a full
seperate windows boot for Arc and Manifold.
I assume I can reference any drive on the machine from Ubunto
regardless of whether it is in a Windows file system or the Mac file
system (i.e. so I can do part of the work such as output cartography in
Arc/Manifold)?
Thanks again,
Neil
On Fri, 01 Jun 2012 02:46:36 -0700, qgis-user-request at lists.osgeo.org
wrote:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: What hardware for QGIS (Harald Hofmann)
> 2. OGRS2012 :: CFP deadline extension to June 15th (Olivier ERTZ)
> 3. Re: Query Layer / Rule Based Rendering Problem (James Stott)
> 4. Re: Query Layer / Rule Based Rendering Problem (Nathan Woodrow)
> Message: 1
> Date: Fri, 01 Jun 2012 08:00:06 +1000
> From: Harald Hofmann <harald.hofmann at monash.edu>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] What hardware for QGIS
> Message-ID: <4FC7E9E6.70103 at monash.edu>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Hi Neil,
> I run QGIS on an iMac i3 (12GB RAM) and on a MacBook Pro i7 (8GB
> RAM).
> Both work fine.
> Installation is super easy. Just follow William Kyngesburye's
> instructions as Lee has already mentioned.
> I think, and I am neither a GIS nor a QGIS specialist (just a very
> limited user), combining QGIS with GRASS gives you the same range of
> functionality as ArcGIS has.
> Again, I am not a hard core GIS person but I used it a bit for
> spatial
> modelling of hydrogeological and hydrological projects.
> The GRASS installation is very easy on a Mac, too (again, follow
> William's instructions ... Thanks William!!!)
> I also had run an ArcView version 9.3 on a virtual computer (on the
> iMac) using VirtualBox and Windows XP with a memory allocation of
> 4GB.
> That also worked fine without any issues. It certainly depends also
> on
> what you want to do. I am not sure about ArcInfo and a Dongle
> compatibility, referring to Lee's answer.
> There is only one thing that I don't like that much with QGIS, which
> is
> making and editing good looking maps for presentations or
> publication.
> It seems a bit clunky to me (e.g. scale issues between QGIS desktop
> and
> map composer, rotation of labels (I have managed it but it took me
> forever to find out how), etc.).
> It is absolutely likely that I don't know all the tricks and tweaks
> how
> to use it but this process seems to be a bit easier in Arc. I usually
> export the map and do the fine editing in a graphics software;
> however,
> it sometimes becomes a bit cumbersome when there is lots to edit that
> potentially could be done much easier by editing a layer in the GIS.
> (to all the others, please comment on that. I want to learn ... )
> Hope that helps,
> Cheers,
> Harald
> On 1/06/12 01:41, Lee Hachadoorian wrote:
>> Hi Neil,
>> I'm not a Mac user, so these partial answers are based on running
>> QGIS
>> on Ubuntu Linux and also running ArcGIS in a VM.
>> On Thu, May 31, 2012 at 4:56 AM,<neil2 at ansergis.net> wrote:
>>> Hello,
>>> I am just getting to know QGIS having taken a brief two day
>>> overview course
>>> at GISRUK 2012 and realised that it really is becoming a practical
>>> alternative to Arc.
>>> One of the many attractions of it is the possibility to also escape
>>> from
>>> windows.
>>> So I am looking at buying an Apple Mac and was hoping for some
>>> advice :
>>> a) What are the limits to the resources that QGIS can realistically
>>> use
>>> (i.e. in the same way that ArcMap is still pretty much stuck with
>>> single
>>> core 32bit processing so there isn't much point sticking 16Gig of
>>> memory in
>>> a machine running it).
>>> b) If I do go with Mac, am I better to install the Mac version of
>>> QGIS or
>>> run Linux also.
>> Installation on Linux is *probably* more straightforward. For
>> installing on Mac, one of my students found
>> http://www.kyngchaos.com/software/qgis helpful. The only reason I
>> can
>> think of to run QGIS in Linux instead of Mac is if you expect to be
>> regularly working with other Linux software and don't want to keep
>> switching OSes. I would definitely try it on Mac first if that's
>> your
>> preferred OS.
>>> c) As I am unlikely to entirely escape ESRI, has anyone experience
>>> of
>>> running ArcGIS on a windows simulator? (i.e. do I need to divide my
>>> resources between two machines).
>> ArcGIS runs fine in a VM. You may run into problems if you need to
>> run
>> a version like ArcInfo that requires a hardware dongle for
>> authentication. I've only been using a version requiring an
>> alphanumeric key. A coworker who tried to get ArcInfo running on a
>> Windows XP guest on a Fedora host eventually just gave up.
>> You do have to divide your resources between machines, but given how
>> much RAM most machines come with these days, that's usually not much
>> of a problem (until you start talking about running multiple guest
>> OSes simultaneously). If you still have access to WinXP, I would
>> consider running Arc on that because of the minimal resource
>> requirements. 1-2 GB of RAM is all you will need (and you could get
>> by
>> on<1 GB of RAM) assuming the guest OS isn't running anything other
>> than Arc. Make sure to dedicate some of your video memory to the
>> guest
>> OS.
>>> d) On the course we ran the linux version of QGIS on a virtual
>>> machine. This
>>> has some attractions in terms of managing various clients projects.
>>> But what
>>> are the performance issues?
>>> Process wise I am likely to need to cover the gamut, from
>>> straightforward
>>> overlay to process models, 3D graphics and visualisation.
>> At my job I run QGIS in an Ubuntu VM on a Windows host (giving it 4
>> out of 12GB of RAM). I haven't noticed any performance issues. The
>> things that are typically slow elsewhere, e.g. multiple layers with
>> many (1000s) features, are still slow, but everything else performs
>> the same as a "real" OS of the same specifications.
>> Best,
>> --Lee
> Harald Hofmann
> Research Fellow PhD - Hydrogeology
> School of Geosciences - Monash University
> Wellington Rd, Clayton, Victoria 3800
> Australia
> Phone: +61 3 99055786
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120601/86697887/attachment-0001.html>
> Message: 2
> Date: Fri, 01 Jun 2012 10:48:15 +0200
> From: Olivier ERTZ <olivier.ertz at heig-vd.ch>
> Subject: [Qgis-user] OGRS2012 :: CFP deadline extension to June 15th
> Message-ID: <4FC881CF.8030900 at heig-vd.ch>
> Content-Type: text/plain; charset=windows-1252; format=flowed
> OGRS2012 :: CALL FOR PAPERS DEADLINE EXTENSION (closing at June 15th)
> Open Source Geospatial Research and Education Symposium
> October 24 ? 26, 2012 in Yverdon-les-Bains, Switzerland
> Hosted by School of Business and Engineering Vaud (HEIG-VD)
> Website: http://www.ogrs2012.org
> Contact: cfp at ogrs2012.org
> (our apologies for cross-postings)
> Dear colleagues,
> the program committee is pleased to announce an extension of the
> submission deadline until June 15th. All information to submit a
> presentation, a workshop, a poster or a discussion group subject is
> available on the symposium website : http://cfp.ogrs2012.org.
> If you were short in time, please consider these last weeks to submit
> your contribution. We look forward to read your contribution proposal
> and to see you in Yverdon-les-Bains.
> We would appreciate if you could kindly distribute this call to other
> interested parties of your acquaintance.
> Please note, registration for OGRS2012 will soon open in early June.
> Best regards,
> OGRS2012 program committee.
> Message: 3
> Date: Fri, 1 Jun 2012 10:31:22 +0100
> From: "James Stott" <James.Stott at npaconsult.co.uk>
> To: <qgis-user at lists.osgeo.org>
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-user] Query Layer / Rule Based Rendering Problem
> Message-ID:
> <B398947DCAB85D46809151E678999F21060FD685 at srv01.NPA.LOCAL>
> Content-Type: text/plain; charset=utf-8
> To update this post,
> I have compared the project file code for both the layer that works
> and
> the layer that doesn't and I have found differences in the
> customproperties section. This section does not exist in the layer
> that
> works - it only exists for the layer that I copied the style for.
> Removing it makes the layer show on the map.
> <customproperties>
> <property key="labeling" value="pal"/>
> <property key="labeling/addDirectionSymbol"
> value="false"/>
> <property key="labeling/bufferColorB" value="255"/>
> <property key="labeling/bufferColorG" value="255"/>
> <property key="labeling/bufferColorR" value="255"/>
> <property key="labeling/bufferSize" value="1"/>
> <property key="labeling/dataDefinedProperty0"
> value=""/>
> <property key="labeling/dataDefinedProperty1"
> value=""/>
> <property key="labeling/dataDefinedProperty10"
> value="16"/>
> <property key="labeling/dataDefinedProperty11"
> value=""/>
> <property key="labeling/dataDefinedProperty12"
> value=""/>
> <property key="labeling/dataDefinedProperty13"
> value=""/>
> <property key="labeling/dataDefinedProperty14"
> value=""/>
> <property key="labeling/dataDefinedProperty2"
> value=""/>
> <property key="labeling/dataDefinedProperty3"
> value=""/>
> <property key="labeling/dataDefinedProperty4"
> value=""/>
> <property key="labeling/dataDefinedProperty5"
> value=""/>
> <property key="labeling/dataDefinedProperty6"
> value=""/>
> <property key="labeling/dataDefinedProperty7"
> value=""/>
> <property key="labeling/dataDefinedProperty8"
> value=""/>
> <property key="labeling/dataDefinedProperty9"
> value="15"/>
> <property key="labeling/decimals" value="0"/>
> <property key="labeling/dist" value="0"/>
> <property key="labeling/distInMapUnits"
> value="false"/>
> <property key="labeling/enabled" value="true"/>
> <property key="labeling/fieldName" value="number"/>
> <property key="labeling/fontFamily" value="MS Shell
> Dlg
> 2"/>
> <property key="labeling/fontItalic" value="false"/>
> <property key="labeling/fontSize" value="8.25"/>
> <property key="labeling/fontSizeInMapUnits"
> value="false"/>
> <property key="labeling/fontStrikeout"
> value="false"/>
> <property key="labeling/fontUnderline"
> value="false"/>
> <property key="labeling/fontWeight" value="50"/>
> <property key="labeling/formatNumbers"
> value="false"/>
> <property key="labeling/isExpression" value="false"/>
> <property key="labeling/labelPerPart" value="false"/>
> <property key="labeling/mergeLines" value="false"/>
> <property key="labeling/minFeatureSize" value="0"/>
> <property key="labeling/obstacle" value="true"/>
> <property key="labeling/placement" value="1"/>
> <property key="labeling/placementFlags" value="0"/>
> <property key="labeling/plussign" value="true"/>
> <property key="labeling/priority" value="5"/>
> <property key="labeling/scaleMax" value="0"/>
> <property key="labeling/scaleMin" value="0"/>
> <property key="labeling/textColorB" value="0"/>
> <property key="labeling/textColorG" value="0"/>
> <property key="labeling/textColorR" value="0"/>
> <property key="labeling/wrapChar" value=""/>
> Using QGIS 1.8.0 on Windows 7
> James
> James Stott BSc (Hons) MSc | Senior Professional
> Nicholas Pearson Associates | 30 Brock Street | Bath | BA1 2LN
> T: 01225 445548 | M: -
> http://www.npaconsult.co.uk/
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of James Stott
> Sent: 31 May 2012 16:22
> Subject: [Qgis-user] Query Layer / Rule Based Rendering Problem
> I have created a query in the DB Manager SQL Window (data is in a
> PostGIS database). The query is then added to the map as a layer.
> I copy the style from another layer (rule based style), paste it to
> my
> query layer and the polygons disappear from the map and QGIS gives a
> nextFeature() without select() error. This also happens if I apply a
> qml
> style file to the layer.
> If I change the styles back to Single Symbol they do not come back. I
> can see the records in the Attribute table, and I can select them and
> zoom to them on the map, I just cannot see them.
> I have to re-add the query layer using the DB Manager SQL window
> again.
> It only seems to be the polygon layers that cause problems at the
> moment.
> Does anyone know the cause of this?
> James
> James Stott BSc (Hons) MSc | Senior Professional Nicholas Pearson
> http://www.npaconsult.co.uk/http://www.npaconsult.co.uk/about-news.asp
> http://www.npaconsult.co.uk/terms.asp
> This Electronic Transmission is intended only for the attention of
> the
> addressee. It may contain privileged and confidential information. If
> you are not the person for whom it is intended, you must not copy,
> distribute or take any action in reliance on it. If you have received
> this electronic transmission in error please notify us immediately by
> telephone, delete the transmission and destroy any hard copies.
> Nicholas Pearson Associates has used all reasonable efforts to ensure
> that this message and any attachments are free from viruses.
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel:
> +44
> (0) 01225 445548, Fax: +44 (0) 01225 312387, Website:
> Message: 4
> Date: Fri, 1 Jun 2012 02:46:27 -0700
> From: Nathan Woodrow <madmanwoo at gmail.com>
> To: James Stott <James.Stott at npaconsult.co.uk>,
> "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Cc: "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>
> Message-ID: <-1181963382601239453 at unknownmsgid>
> Content-Type: text/plain; charset=ISO-8859-1
> I had this issue the other day when I used the Copy Style function.
> Must be a bug. Can you fill a ticket for it.
> Nathan
> Sent from some fancy phone looking thingo
> From: James Stott
> Sent: 1/06/2012 7:31 PM
> and
> that
> <customproperties>
> value="false"/>
> value=""/>
> value=""/>
> value="16"/>
> value=""/>
> value=""/>
> value=""/>
> value=""/>
> value=""/>
> value=""/>
> value=""/>
> value=""/>
> value=""/>
> value=""/>
> value=""/>
> value="15"/>
> value="false"/>
> Dlg
> 2"/>
> value="false"/>
> value="false"/>
> value="false"/>
> value="false"/>
> James
> my
> qml
> again.
> moment.
> James
> the
> +44
> End of Qgis-user Digest, Vol 76, Issue 1
