[Qgis-user] shapefile/dbf number limitation?
Christine
geo.guide at web.de
Sun Jun 10 13:43:04 PDT 2012
Thanks for the hint, Zirneklitis !
"You can't use REAL field type for ID as it a bit approximately, e.g.,
number '1234567890123456789' will memorised as '1,23456789012347E+018'.
The INTEGER should be used instead.
Wasn't our/my idea to do so. The file was created by authorities and we had
to process it.
Seems, that this works with the given definition in ArcGIS - however ESRI is
achieving that.
Regards, Christine
View this message in context: http://osgeo-org.1560.n6.nabble.com/shapefile-dbf-number-limitation-tp4891669p4980251.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
