[Qgis-user] QGIS 1.8 quits while loading layers
    Ben Harrison
    ben.harrison at liquidmesh.com
    Sat Jun 16 20:59:50 PDT 2012
On 17 June 2012 13:50, mick <bareman at tpg.com.au> wrote:
> Run it from a xterm then it will give you some kind of error message
> mick
OK, did that, and here are the messages (slightly edited for clarity):
ERROR 4: `/home/harb/Documents/Varma et al fig 9.png' does not exist in the
file system,
and is not recognised as a supported dataset name.
ERROR 4: `/home/harb/Documents/Varma et al fig 7_modified.tif' does not
exist in the file system,
ERROR 4: `/home/harb/Documents/Varma et al fig 9_modified.tif' does not
ERROR 10: Pointer 'hDS' is NULL in 'OGR_DS_Destroy'.
ERROR 4: `/home/harb/Downloads/meanan/meanann.txt' does not exist in the
file system,
Segmentation fault
So, it's causing a segmentation fault when it can't find a data source?
Seems extreme. Could be handled better? I know this other GIS software that
does it differently ...
Ben.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120617/1d81dba7/attachment.html>
