[Qgis-user] otb plug in qgis
Giuseppe Amatulli
giuseppe.amatulli at gmail.com
Mon Jun 18 15:27:19 PDT 2012
Ciao
I have some trouble in getting OTB plunging working in qgis.
I'm using Ubuntu 12.04 (gdal 1.9) and i install all the otb modules from
deb http://ppa.launchpad.net/otb/orfeotoolbox-nightly/ubuntu precise main
deb-src http://ppa.launchpad.net/otb/orfeotoolbox-nightly/ubuntu precise main
apt-get install libotb libotb3-dev monteverdi otbapp-legacy
otbapp-common otbapp-cli
otbapp-fltk otbapp-qt otbapp otb-bin-common otb-bin otb-bin-qt
python-otb libotb3.13
if i start qgis
during the qgis-opening
i get
Could not find the Python bindings for OrfeoToolbox, which are
required to run the this module
Couldn't load plugin otb due an error when calling its classFactory() method
File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 164, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "/home/user/.qgis//python/plugins/otb/__init__.py", line 59, in
classFactory
even if i set
export LD_LIBRARY_PATH=/usr/lib/otb
export PYTHONPATH=/usr/lib/otb/python:$PYTHONPATH
export ITK_AUTOLOAD_PATH=/usr/lib/otb/applications/
end then open
qgis
i get during the precessing modules open
An error has occurred while executing Python code:
File "/home/user/.qgis//python/plugins/processingmanager/__init__.py",
line 71, in populateMenu
self.panel = Panel(self._iface)
File "/home/user/.qgis//python/plugins/processingmanager/panel.py",
line 61, in __init__
The precessing modules contain saga and other modules but not otb.
Any suggestions?
Thanks
Giuseppe Amatulli
Web: www.spatial-ecology.net
