[Qgis-user] Kindly help
Andreas Neumann
a.neumann at carto.net
Tue Jun 19 00:34:05 PDT 2012
Hi Abel,
There is a conflict of the ssleay32.dll - QGIS uses this library for
encrypted connections (e.g. to databases). Another application installed
a different version that is not compatible with QGIS. You need to copy
the ssleay32.dll that QGIS or the OSGeo4W to the application directory
where qgis.exe / qgis.bat reside.
See also this discussion:
http://osgeo-org.1560.n6.nabble.com/Libeay32-dll-version-conflict-td4531341.html
Hope this helps,
Andreas
Am 19.06.2012 08:43, schrieb abel mtui:
> I am installing QGIS, but it fail to open after installation and the
> following message appears qgis-exe-ordinal not found.The ordinal 284 could
> not be located in the dynamic link library SSLEAY32.dll
> Rgds
> Abel
> Qgis-user mailing list
