[Qgis-user] QGIS Master and Rasters to grayscale
Etienne Tourigny
etourigny.dev at gmail.com
Tue Jun 19 04:51:39 PDT 2012
You can still do that by selecting "singleband gray", and choose the
default contrast enhancement in the options.
On Tue, Jun 19, 2012 at 8:42 AM, James Stott
<James.Stott at npaconsult.co.uk>wrote:
> This does make what was a very simple thing to do in 1.8 more time
> consuming in 1.9 doesn’t it? All I want to do is just turn it grayscale for
> display purposes. In 1.8, all I do is select grayscale from the colormap
> drop down and push OK and QGIS does it for me. Am I missing something?****
> James ****
> *James Stott* BSc (Hons) MSc | Senior Professional
> *Nicholas Pearson Associates * | 30 Brock Street | Bath | BA1 2LN
> *T:* 01225 445548 | *M:* -
> *www.npaconsult.co.uk* <http://www.npaconsult.co.uk/>
> *From:* Marco Hugentobler [mailto:marco.hugentobler at sourcepole.ch]
> *Sent:* 19 June 2012 10:49
> *To:* James Stott
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] QGIS Master and Rasters to grayscale****
> shows what happens when I use the method detailed below.
> Is it a raster with integer values (but without color table)? In that
> case, switch the renderer type to singleband pseudo color and insert the
> color for each value.
> Marco
> Am 19.06.2012 11:18, schrieb James Stott: ****
> shows what happens when I use the method detailed below.****
> I would like the raster to display as in the 1.8 jpg.****
> QGIS 1.8 https://docs.google.com/open?id=0B6r5nAOdEBZrSjhyaHdoUW9LY0U****
> QGIS 1.9 https://docs.google.com/open?id=0B6r5nAOdEBZrLUJ1dDNNM3BJZVE ****
> *Nicholas Pearson Associates *| 30 Brock Street | Bath | BA1 2LN
> *www.npaconsult.co.uk* <http://www.npaconsult.co.uk/> ****
> *From:* qgis-user-bounces at lists.osgeo.org [
> mailto:qgis-user-bounces at lists.osgeo.org<qgis-user-bounces at lists.osgeo.org>]
> *On Behalf Of *Marco Hugentobler
> *Sent:* 19 June 2012 09:49
> *To:* qgis-user at lists.osgeo.org
> Hi James
> You may go to the raster properties, select render type singleband gray.
> Then select contrast enhancement 'stretch to min/max' and click on 'load'
> to get the min/max values from the datasource.
> Having this by default (options page) is not yet available with the new
> raster classes. A bugticket is already filled.
> Regards,
> Marco
> Am 19.06.2012 10:17, schrieb James Stott: ****
> I sometimes display my Ordnance Survey rasters as single band gray to
> allow my data to show more clearly over the top of it.****
> In the new master I cannot achieve the same effect. My raster goes solid
> grey.****
> Old settings:****
> Render as: Single Band gray****
> Single band properties – gray band: Band 1****
> Single band properties – color map: grayscale****
> New settings:****
> Render type: Singleband gray****
> Gray band: Palette****
> Contrast enhancement: No enhancement****
> How do I achieve the same effect as before? The raster displays fine in
> colour, just not in grayscale. I am guessing it’s down to the new raster
> properties in master.****
> [image: Nicholas Pearson Associates, Logo] <http://www.npaconsult.co.uk/>[image:
> Nicholas Pearson Associates, Latest News]<http://www.npaconsult.co.uk/about-news.asp>
> Information and Registered Address <http://www.npaconsult.co.uk/terms.asp>
> This Electronic Transmission is intended only for the attention of the
> addressee. It may contain privileged and confidential information. If you
> are not the person for whom it is intended, you must not copy, distribute
> or take any action in reliance on it. If you have received this electronic
> transmission in error please notify us immediately by telephone, delete the
> transmission and destroy any hard copies. ****
> Nicholas Pearson Associates has used all reasonable efforts to ensure that
> this message and any attachments are free from viruses.****
> Nicholas Pearson Associates, 30 Brock Street, Bath, BA1 2LN , Tel: +44 (0)
> 01225 445548, Fax: +44 (0) 01225 312387, Website:
> http://www.npaconsult.co.uk****
> _______________________________________________****
> Qgis-user mailing list****
> Qgis-user at lists.osgeo.org****
> http://lists.osgeo.org/mailman/listinfo/qgis-user****
> Dr. Marco Hugentobler****
> Sourcepole - Linux & Open Source Solutions****
> Weberstrasse 5, CH-8004 Zürich, Switzerland****
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch****
> Technical Advisor QGIS Project Steering Committee****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/926d59f4/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/926d59f4/attachment.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120619/926d59f4/attachment-0001.jpg>
