On Wed, 2012-06-20 at 10:12 -0400, Gerardo Jimenez wrote: > I can do that in linux...but in windows 7? you can run programs from the terminal also under Windows :) if you used osgeo4w just open the terminal in c:\osgeo4w\bin and the command should be qgis.bat --noplugins cheers -- Giovanni --
