[Qgis-user] qgis-gdal: color-table problem to transform rasterimge
Jan Tappenbeck
osm at tappenbeck.net
Wed Jun 20 07:19:30 PDT 2012
hi !
i have to transform rasterimages from gauss-krueger to etrs by using
gsb-files.
one of the image is:
Driver: GTiff/GeoTIFF
Files: C:/Users/tappenbeck/Desktop/Haan_Transformation/BP_001.tif
C:/Users/tappenbeck/Desktop/Haan_Transformation/BP_001.tfw
Size is 1862, 2990
Coordinate System is `'
Origin = (2570979.517376476900000,5673843.182623745900000)
Pixel Size = (0.085247046186886,-0.085247491638684)
Metadata:
TIFFTAG_SOFTWARE=IrfanView
TIFFTAG_XRESOLUTION=200
TIFFTAG_YRESOLUTION=200
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
COMPRESSION=PACKBITS
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 2570979.517, 5673843.183)
Lower Left ( 2570979.517, 5673588.293)
Upper Right ( 2571138.247, 5673843.183)
Lower Right ( 2571138.247, 5673588.293)
Center ( 2571058.882, 5673715.738)
Band 1 Block=1862x4 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 0,0,0,255
1: 255,255,255,255
2: 251,243,215,255
3: 251,238,211,255
4: 251,238,206,255
254: 227,230,230,255
255: 255,255,255,255
i want to use a gdal-statement by sven geggenus [1] for transformation.
i open the gdal-function gdal > transformation (projection) and i copy
the modify source in the command area at the buttom of the dialog:
gdalwarp -r cubicspline -multi -of HFA -s_srs "+init=epsg:31466
+nadgrids=C:/Users/Tappenbeck/Desktop/Haan_Transformation/Mettmann_Beta2007.gsb
+wktext" -t_srs EPSG:25832 -of GTiff
C:/Users/tappenbeck/Desktop/Haan_Transformation/BP_001_trans.tif
after apply the command i get following message:
Output dataset
C:/Users/tappenbeck/Desktop/Haan_Transformation/BP_001_trans.tif exists,
but some commandline options were provided indicating a new dataset
should be created. Please delete existing dataset and run again.
can anyone help me to do the transformation ?
ADDITITION:
it is only possible to modify the gdad-command for single use - file by
file.
is it possible to use usermodifiy-command for folder-transformations ?
please help.
reagards Jan :-)
[1]
http://www.fossgis.de/konferenz/2010/attachments/71_osm-datenaufbereitung-fossgis-2010.pdf
- Page 8
