[Qgis-user] help to list files by bourne-shell
Alister Hood
Alister.Hood at synergine.com
Wed Jun 20 17:07:40 PDT 2012
> Date: Wed, 20 Jun 2012 17:02:51 +0200
> From: Zoltan Szecsei <zoltans at geograph.co.za>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] help to list files by bourne-shell
> Message-ID: <4FE1E61B.8050607 at geograph.co.za>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> On 2012/06/20 16:36, Jan Tappenbeck wrote:
> > hi !
> > i want to create a script for use in msys - but i am not a linux-user.
> > i try to create this by a template:
> > #!/bin/sh
> > # Einfaches Beispiel
> > for i in C:/Users/tappenbeck/Desktop/Project/*;
> > do
> > if [ -d "$i" ];
> > then
> > echo $i is directory;
> > fi;
> > done
> > but there will no files list - can anyone help me ?
If you actually mean there are no _directories_ listed, I don't know what's going on. It works for me, either running the script from the msys rxvt, or from the msys dos prompt (by running `sh script_path_and_name`).
If you really do mean there are no _files_ listed, try adding `else echo $i is file`.
BTW, they don't hurt, but you don't need any of those semicolons at the end of lines (;). You need semicolons to separate separate commands that you want to write on the same line.
> > reagards Jan :-)
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> The syntax should be:
> for i in `ls xxx/*`
> do
> etc
If you want to do that, why complicate things by using ls?
Why not just use `for i in */*; do` ?
> but if you have spaces in your file names, i will contain the words
> delimited by these spaces.
> fiddle with something like:
> ls -1 xxx/* > myfiles
> while read i
> do
> wadda-wadda
> done<myfiles
> rm myfiles
> HTH,
> Zoltan
Alister
