[Qgis-user] different problems with merge images
Jan Tappenbeck osm at tappenbeck.net
Thu Jun 21 06:23:51 PDT 2012
Hi !
i had to merge several images to one large an have even problems with
the color. (the data of my two test-image you found at the end of this
posting)
if i merge this two images via qgis-gdal > merge i get two different,
but unuseable, images
look at the following images:
with pseudocolortable for the first image -
http://www.tappenbeck.net/forum/gdal/gdal_qgis_with_colortable.jpg
without pseudocolortable for the first image -
http://www.tappenbeck.net/forum/gdal/gdal_qgis_without_colortable.jpg
other problem can anyone tell me the right way ?
when i try to start the command via msys like:
gdal_merge.bat -pct -of GTiff -o
E:/jan_testauswertungen/xxxx_test/Luftbild/dialog_mit.tif
E:/jan_testauswertungen/xxxx_test/Luftbild/675730.tif
E:/jan_testauswertungen/xxxx_test/Luftbild/675735.tif
i get the message in qgis 1.7.4 - windows7:
/c/QuantumGISWroclaw/bin/gdal_merge.bat: line 1: @python: command not found
did i use the alternative command gdalwarp like
gdalwarp  E:/jan_testauswertungen/xxxx_test/Luftbild/675730.tif
E:/jan_testauswertungen/xxxx_test/Luftbild/gdalwarp.tif
i get the same result like
???? why ?????
in hope of a helpfull answer
reagards Jan :-)
image data
Driver: GTiff/GeoTIFF
Files: E:/jan_testauswertungen/haan_test/Luftbild/675730.tif
        E:/jan_testauswertungen/haan_test/Luftbild/675730.tfw
Size is 10000, 10000
Coordinate System is `'
Origin = (2567500.000000000000000,5673500.000000000000000)
Pixel Size = (0.050000000000000,-0.050000000000000)
Metadata:
   TIFFTAG_SOFTWARE=IrfanView
   TIFFTAG_XRESOLUTION=72
   TIFFTAG_YRESOLUTION=72
   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( 2567500.000, 5673500.000)
Lower Left  ( 2567500.000, 5673000.000)
Upper Right ( 2568000.000, 5673500.000)
Lower Right ( 2568000.000, 5673000.000)
Center      ( 2567750.000, 5673250.000)
Band 1 Block=10000x1 Type=Byte, ColorInterp=Palette
   Overviews: 5000x5000, 2500x2500, 1250x1250, 625x625, 313x313,
157x157, 79x79
   Color Table (RGB with 256 entries)
     0: 15,14,14,255
     1: 83,133,59,255
     2: 103,137,153,255
     3: 43,63,119,255
     4: 42,69,35,255
Files: E:/jan_testauswertungen/haan_test/Luftbild/675735.tif
        E:/jan_testauswertungen/haan_test/Luftbild/675735.tfw
Origin = (2567500.000000000000000,5674000.000000000000000)
Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( 2567500.000, 5674000.000)
Lower Left  ( 2567500.000, 5673500.000)
Upper Right ( 2568000.000, 5674000.000)
Lower Right ( 2568000.000, 5673500.000)
Center      ( 2567750.000, 5673750.000)
157x157, 79x79
     0: 15,17,17,255
     1: 84,138,59,255
     2: 102,139,159,255
     3: 36,57,121,255
     4: 47,74,35,255
