[Qgis-user] Error 14 -- Unable to open ~/.qgis//qgis.db -- QGIS version 1.8.0-Lisboa -- Ubuntu 12.04
    Etienne Tourigny
    etourigny.dev at gmail.com
    Sun Jun 24 13:39:21 PDT 2012
You probably have permission problems or a corrupt file.
Rename your .qgis folder to .qgis.bak and restart qgis. Do not copy
qgis.db from elsewhere.
Etienne
On Wed, Jun 20, 2012 at 2:34 PM, Goyo <goyodiaz at gmail.com> wrote:
> 2012/6/20 Paul Young <paulysa at gmail.com>:
>> I get this error: Error 14 -- Unable to open ~/.qgis//qgis.db -- QGIS
>> It was discovered when I tried to define a custom CRS and save it under:
>> settings/custom CRS in QGIS 1.80.-Lisboa under Ubuntu 12.04 and saving the
>> custom CRS indicated this error.
>> I notice that the qgis.db file is located at:
>> /usr/share/qgis/resources/qgis.db
> There should be one at  ~/.qgis too.
>> I created a link but this did not work either. Can I tel QGIS to look for
>> the qgis database at the above location rather that ~/.qgis//?
> Better make a copy of qgis.db into ~/.qgis.
>> Looks like permissions are read and write for all users.
> That sounds weird to me. This is what I get (qgis master, ubuntu 12.04):
> $ ls -l /usr/share/qgis/resources/qgis.db
> -rw-r--r-- 1 root root 23552 may  7  2011 /usr/share/qgis/resources/qgis.db
> The owner is root and only root has write permissions. Which is to be
> expected for a file in that directory.
> Goyo
> Qgis-user mailing list
