[Qgis-user] QGIS WEB Client / Qgis Server
Till Adams
adams at terrestris.de
Mon Jun 25 05:18:34 PDT 2012
Dear Kadu,
this looks like an installation problem of your qgis-server as it is not
able to deliver a map on a getmap-request. The labels and so are drawn
by OpenLayers, the core of the QGIS client.
It's easier to test the pure qgis-server installation first and try via
the getmap request, before using QGIS-client as you have less dependencies.
I tried my best for a windows-install howto, look here:
http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial#Windows
I would suggest to check this first.
Regards, Till
On 25.06.2012 14:12, Kadu Machado wrote:
> Hi folks....
> I have a little issue with Qgis WebClient over Windows....
> When I access the qgis web client, the layers and labels are loaded and
> are showed normally, but the map dont.... After the message loading map,
> the map just dont open. The frame is still blank.
> I notice that a Internal Error 500 occour:
> 1. GET
> http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:\projetos\redes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300
> <http://srv-vibgeo01/qgis/qgis_mapserv.fcgi.exe?map=c:%5Cprojetos%5Credes.qgs&LAYERS=pk_kombiniert&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=174575.63035781,8246018.1303578,194419.36964219,8265861.8696422&WIDTH=300&HEIGHT=300>
> 500 (Internal Server Error) OpenLayers.js:1000
> <http://srv-vibgeo01/maps/libs/openlayers/OpenLayers.js>
> Anyone has some ideia how to solve this problem???
> "Quem quer fazer alguma coisa, encontra um meio. Quem não quer fazer
> nada, encontra uma desculpa."
> (Roberto Shinyashiki)
> Qgis-user mailing list
--> GO Mobile - jetzt WebGIS auch auf Smartphones <--
! Achtung - terrestris hat eine neue Adresse !
terrestris GmbH & Co. KG
Puetzchens Chaussee 56
53227 Bonn
Germany
Till Adams
Geschaeftsfuehrung
Tel: +49 (0)228 / 962 899-52
Mobile: +49 (0)151 / 25394429
Fax: +49 (0)228 / 962 899-57
http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementaerin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
