[Qgis-user] QGIS Webclient PostgreSQL search table
Dennis Ströer dennis.stroeer at geosysnet.de
Mon Jun 25 07:41:16 PDT 2012
Hey Bernhard,
thank you for the advice, this solution seems to be logical. I created a
view like you told me. After this I changed the GlobalOptions.js to:
var useGeoNamesSearchBox = false;
var searchBoxQueryURL = "/wsgi/search.wsgi?query=";
var searchBoxGetGeomURL = "/wsgi/getSearchGeom.wsgi";
and put the name of the view in the according fields in search.wsgi and
getSearchGeom.wsgi. I also named the required connection paramters there
and activated the sql searchstring line...
But when I try to write a searchtext in the client, Firebug gives the
error message:
"illegal character
#!/usr/bin/python"
And when execute a sample query in Firefox, like written in the
search.wsgi file, Firefox only visualize the file search.wsgi like a
text file.
I think the configuration of the mod_wsgi or something else failed before?!
Cheers,
D. Stroeer
> Hi Dennis,
> the documentation might be a bit misleading. In fact you have to
> insert with to_tsvector(somestring).
> I normally use views as search relations so if I have a table
> streets(gid, the_geom, streetname)
> it would be something like
> CREATE OR REPLACE VIEW search_streets AS
>  SELECT streetname AS searchstring,
> streetname::text AS displaytext,
> '02_Streets'::text AS search_category,
> the_geom,
> 'MULTILINESTRING'::text AS geometry_type,
> -- here it comes:
> to_tsvector(streetname::text ) AS searchstring_tsvector
> FROM streets
> Bernhard
> > displaytext text NOT NULL, --the display text for the search combobox,
> > e.g. "Z~ 1 richstrasse 46, 8610 Uster (address
> > search_category text, --should have a leading two digit number:, e.g.
> > --"03_parcels", where 03 is the order of the search categories, the
> number
> > --should be unique across all search tables
> > the_geom geometry,
> > --the actual geometry
> > geometry_type text,
> > --the geometry type as returned by ST_GeometryType(the_geom)
> Am 25.06.2012 14:30, schrieb Dennis Ströer:
>> Am 25.06.2012 14:09, schrieb Bernhard Ströbl:
>>> Hi Dennis,
>>> please try to execute SELECT to_tsvector('bla') in a SQL shell.
>>> What happens?
>>> Your error message indicates you call the funtion without an argument.
>>> Maybe you should read the doc on the Full text Search
>>> http://www.postgresql.org/docs/8.4/static/textsearch.html
>>> and/or the tsvector data type
>>> http://www.postgresql.org/docs/8.4/static/datatype-textsearch.html
>>> Bernhard
>>> Am 25.06.2012 13:11, schrieb Dennis Ströer:
>>>> Hello everybody,
>>>> I'm testing the QGIS webclient in the moment. Thanks for developing
>>>> such
>>>> a great project! Its a nice tool and the default settings and
>>>> functionality works fine. Now I'm trying to realize the search with
>>>> wsgi
>>>> and a PostgreSQL table setup for searching like explained in the
>>>> chapters 6 and 7 of the installation guide.
>>>> I created a searchtable and now I want to fill it with some test data,
>>>> but a problem appears. When I want to fill the field
>>>> searchstring_tsvector with the value to_tsvector() I'm getting the
>>>> following error:
>>>> ERROR: function to_tsvector() does not exist
>>>> I'm using PostgreSQL 8.4, so I think the tsearch package is already
>>>> included?! And when I add a new column to a table I can select the
>>>> data
>>>> type tsvector...
>>>> Do I have to create the function to_tsvector by hand?
>>>> Does anybody know a solution for this error?
>>>> Cheers,
>>>> D. Stroeer
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> ________ Information from NOD32 ________
>>> This message was checked by NOD32 Antivirus System for Linux Mail
>>> Server.
>>> http://www.nod32.com
>> Hey guys,
>> thanks for the quick response!
>> Like Andreas told me, I executed the tsearch2.sql script which installed
>> the data types and function. If I execute SELECT to_tsvector('bla') it
>> returns 'bla' :1, so I think it works fine.
>> But if I try to fill the searchtable, the same error message appears:
>> Like Bernhard mentioned, it seems that I call the funtion without an
>> argument. But when I look at the example in the installation guide on
>> page 16, it seems to me, that I have to:
>> CREATE TABLE public.searchtable
>> searchstring text, --the search string (all lower case), e.g. "z~ 1
>> richstrasse 46, 8610 uster"
>> number
>> the_geom geometry,
>> geometry_type text,
>> searchstring_tsvector tsvector, *-- be sure to fill this with
>> to_tsvector()*
>> CONSTRAINT searchtable_pkey PRIMARY KEY (displaytext)
>> WITH (
>> OIDS=FALSE
>> Cheers,
>> D. Stroeer
>> *________ Information from NOD32 ________*
>> Server.
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
