[Qgis-user] Encoding problem in QGIS 1.8
Błażej Zamojski blazej.zamojski at rdos.krakow.pl
Tue Jun 26 01:06:32 PDT 2012
Thanks, I'll check does it work, but it doesn't solve the problem. It will be a serious obstacle for upgrade and could discourage people.
B.
-----Original Message-----
From: Alexander Bruy [mailto:alexander.bruy at gmail.com]
Sent: Monday, June 25, 2012 7:46 PM
To: blazej.zamojski at rdos.krakow.pl
Subject: Re: [Qgis-user] Encoding problem in QGIS 1.8
you can try custom build from NextGIS [0] where this problem solved.
[0] http://nextgis.ru/en/nextgis-qgis/
2012/6/25  <blazej.zamojski at rdos.krakow.pl>:
> Hi
> I'm trying a workaround for problems with non-latin characters in QGIS 1.8
> (http://ssrebelious.blogspot.com/2012/03/qgis-and-gdal19-encoding-issue.html)
> on WinXP 32-bit, but this solution is not working. Do you know any other way
> for that? I know this is GDAL issue, but it is very important for QGIS users
> to have it repaired. Is there any chance for that? I want to upgrade in my
> institution to 1.8 but without polish letters it will be impossible. Maybe
> there is possibility to compile 1.8 with older GDAL version? I will
> appreciate any help.
> blazej
Alexander Bruy
