[Qgis-user] QGIS 1.8.0 Issues on Ubuntu 12.04
    Alex Mandel
    tech_dev at wildintellect.com
    Tue Jun 26 09:10:12 PDT 2012
If you want newer GDAL you have to install using the Ubuntugis PPA not
the qgis.org one.
Thanks,
Alex
On 06/26/2012 09:08 AM, Ted wrote:
> Yes,
> been having some issues with the QGIS 1.8 on Ubuntu 12.04
> What surprise me is that, the GDAL version used is 1.7.4 while its 1.9.1 in
> Windows.
> Hope someone can help.
> Another issue was, the dropdown scale setting. Someone promised to fix that
> in final release , not sure if that was done.
> Thanks
> Ted.
> On Mon, Jun 25, 2012 at 5:41 PM, Paul Shapley <p.shapley at gmail.com> wrote:
>> Hi Users,
>> Are any other users getting similar problems to me?. All of which worked
>> in 1.7.4 on ubuntu 12.04.
>>    - Opening older project files crash QGIS 1.8.0?
>>    - Setting the CRS to EPSG: 27700 (OSGB/36) causes 1.8 to crash?
>>    - adding a PostGIS layer causing a crash?
>>    - qgis_mapserv.fcgi - Now have '500 internal server errors' in browser.
>>    - WMS setup from a QGIS project no longer works.
>> repository used was:
>> deb           http://qgis.org/debian precise main
>> deb-src     http://qgis.org/debian precise main
>> compiled against GDAL/OGR 1.7.3
>> Paul J. Shapley
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
