[Qgis-user] mmqgis plugin error
Sindile Bidla
sindile.bidla at gmail.com
Tue Jun 26 10:48:59 PDT 2012
There is a conflict between the mmqgis and sextante plugin as per this
discussion
http://osgeo-org.1560.n6.nabble.com/mmqgis-plugin-broken-td4681170.html
Uninstalling the sextante plugin and installing mmqgis seems to be a
solution.
On Jun 26, 2012 12:57 PM, "Harish" <harry.om2000 at gmail.com> wrote:
> When I tried to install mmqgis plugin the following message appeared:
> The plugin seems to be invalid or have unfulfilled dependencies.It has
> been installed by can't be loaded. If you really need this plugin, you can
> contact its author or QGIS Users Group and try to solve the problem, if not
> you can just uninstall it. Here is the error message below:
> The plugin is broken. Python said:
> 'module object has no attribute 'classFactory'
> Using QGIS 1.8 on XP.
> Harish Kumar Solanki, Assistant Professor
> National Institute of Rural Development (NIRD), MoRD, GoI
> Jaipur, INDIA- 302006
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120626/42d83436/attachment.html>
