[Qgis-user] How to display an arrow pointing at a certain bearing from a point file
Jeremy Hill
hije14 at gmail.com
Wed Jun 27 01:55:09 PDT 2012
I have a number of point features which contain an attribute I call "bearing" and another one called "slope". Each point has a bearing between 0 to 359 degrees. And the slope is either "+15" or "-15", etc, such as +15% or -15% depending on the steepest slope of the ground.
What I am wanting to do is display an arrow on the map with the arrow pointing in the bearing direction. With a negative slope% pointing outward from the point and a positive slope% pointing inward to the point.
I'm using this in a forestry context with cruise plots. I'm fairly certain that ArcGIS can do this (As I've seen it on maps) but I'm hoping that QGIS can as well.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120627/bb4d3b47/attachment.html>
