[Qgis-user] Add a point on a layer using lat/long coordinates
lt
bisnulama at hotmail.com
Wed Jun 27 22:04:43 PDT 2012
you can create a table with lat/long coordinates, save it as csv, then you can use the csv import plugin and specify the correct csv (epsg 4326 or else)
lt
Date: Wed, 27 Jun 2012 16:01:47 -0800
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Add a point on a layer using lat/long coordinates
Message-ID: <4FEB9EEB.1000605 at NUSalaska.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hello,
Lets say I have a set of lat/long coordinates that i would like to add
as points to an existing layer in my map. How would i do that?? I saw
that the numerical vertex editor plugin will let me add x,y coordinates
but that has to be in reference to something and i don't know what the
reference is. It would be much handier to be able to just add the points
via lat/long coordinates.
Thanks for your help,
Daniel Kranich
Northern Utility Services
Daniel at NUSalaska.com
(907)242-9820
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120628/3aac05f4/attachment.html>
