[Qgis-user] DXF EXPORT
Bis Nulama bisnulama at hotmail.com
Wed Jun 27 23:57:22 PDT 2012
Autocad says:
The database manager is not valid: 0 to the line 1548.
 Invalid or incomplete DXF input - drawing deleted.Then it crashes
I tried to delete line 1548 but it doesn't work
I tried to open the dxf file with Inkscape, I do not get errors but it seems to be empty...
laura
Date: Wed, 27 Jun 2012 14:09:55 -0500
Subject: Re: [Qgis-user] DXF EXPORT
To: bisnulama at hotmail.com
The error might help.If it happens to be a line numbered erro and happens to be an ascii dxf you can open (as long as the mb size is not too large) in a notepad. edit the offending line and save.
 On Wed, Jun 27, 2012 at 12:08 PM, lt <bisnulama at hotmail.com> wrote:
I try to open the dxf file with AUTOCAD2007 LT and I cannot open it: I get an error. then the opened file appears to be empty.any suggestion?laura
Date: Wed, 27 Jun 2012 11:39:54 +0300
To: qgis-user at lists.osgeo.org
Message-ID: <4FEAC6DA.4090601 at lanet.lv>
Content-Type: text/plain; charset=UTF-8; format=flowed
Is it realy empty file or the exported layer can not be imported in
drawing applications?
There was a dxf export bug prior to gdal 1.9.1.
Now it's fixed.
http://trac.osgeo.org/gdal/ticket/4618
Karlis
Bis Nulama wrote:
Hello, how can I export a shp file to dxf format?
I am using qgis 1.7.4 under winXP. The save as->dxf does not work. It
creates the dxf file, but it is empty!
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120628/b0c79189/attachment.html>
