[Qgis-user] Landsat scene as GeoTIFF
Ramon AndiƱach custard at westnet.com.au
Fri Mar 2 00:10:28 PST 2012
I'd guess a plugin has been installed and forgotten about.
There's one with a fairly obvious name that might fit the bill.
(also your correspondent is using master/1.9, so if  you do install the plugin the menu will turn up in your plugin menu - not in Layers)
-ramon.
On 02/03/2012, at 15:47, Zirneklitis <eko at lanet.lv> wrote:
> There is no such a menu  entry neither under Layer nor somewhere else :(
> (Using QGIS 1.7.4 / 1.9.90)
> K.
> ronczyk levente wrote:
> > Layer > Add  RGB Composation / select the bands and that's all
> > 2012/3/2 Zirneklitis <eko at lanet.lv <mailto:eko at lanet.lv>>
> >     I have a Landsat scene as seperate GeoTiff files for each band. Is
> >     possible to load them in QuantumGIS as a single layer? I want to
> >     use three band colour to display them.
> Qgis-user mailing list
