AW: [Qgis-user] qgis crash when exporting to pdf, svg or image
Peter Schürch
p.schuerch at meierpartner.ch
Mon Mar 5 03:15:30 PST 2012
Have just downloaded and installed QGIS 1.6.0 as windows .exe installer to proceed as suggested.
However, my qgis project file won't open in the older version. Version 1.6.0 crashes immediately.
Are project files in general not downward compatible??
Peter
-----Ursprüngliche Nachricht-----
Von: Giovanni Manghi [mailto:giovanni.manghi at faunalia.pt]
Gesendet: Montag, 5. März 2012 11:26
An: Peter Schürch
Cc: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] qgis crash when exporting to pdf, svg or image
> Any Ideas how to get to the bottom of this problem? Are there any known do's or don'ts I should obey?
I answered to the same question minutes ago. If you are using Windows it seems to be a memory problem. It would be important to test also qgis
1.6 because I have reports that this issue surfaced in qgis 1.7.x, and so it can be a regression.
cheers
-- Giovanni --
