[Qgis-user] Labeling area
Nathan Woodrow
madmanwoo at gmail.com
Mon Mar 5 23:16:41 PST 2012
This feature is only in the current dev build. It will be in 1.8 although
there is no ETA on when that will be released
- Nathan
On Tue, Mar 6, 2012 at 5:10 PM, Starke Holger, Mag. <Starke at hagel.at> wrote:
> Hello,****
> I´m using QGIS 1.6 on several tablets and I didn´t found any
> „expression-based-labeling“ in 1.7.4 also. Where can I find this feature?*
> Thanks!****
> Holger****
> *Von:* Nathan Woodrow [mailto:madmanwoo at gmail.com]
> *Gesendet:* Montag, 05. März 2012 10:38
> *An:* Starke Holger, Mag.
> *Cc:* qgis-user at lists.osgeo.org
> *Betreff:* Re: [Qgis-user] Labeling area****
> Sure if you running the latest dev version of QGIS you can use expression
> based labelling
> http://woostuff.wordpress.com/2011/10/27/expression-based-labeling/****
> - Nathan****
> On Mon, Mar 5, 2012 at 7:11 PM, Starke Holger, Mag. <Starke at hagel.at>
> wrote:****
> Hello,****
> I would like to digitize polygons and label them with their area, but it
> isn´t possible to select the area of a polygon as the label-field. I could
> open the Attribute Table and add a new column and calculate the area, but
> it should be displayed immediately after finishing digitizing, ist this
> possible?****
> Holger****
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120306/bf0225e1/attachment.html>
