[Qgis-user] downloading from GPS device
ahs ahs
ahsqgis at hotmail.com
Tue Mar 6 00:17:06 PST 2012
There are no spaces in the path, so that is not the problem.
Date: Mon, 5 Mar 2012 14:49:03 +0200
To: ahsqgis at hotmail.com
CC: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] downloading from GPS device
On 05/03/2012 14:38, ahs ahs wrote:
Hi
I can not download
data from a GPS device. I open the GPS tools and the tab
"Download from GPS". At "GPS device", correctly "Garmin
serial" shows. "Port" I set to usb (have also tried the
other alternatives). I set the feature type, fill in Layer
name, "test". In "Output file", I am not sure about whether
I should chose an existing gpx-file or name a new one, but
neither alternative works. If I try to create a new one
here, I get the error message "Layer is not valid. The layer
test13.gpx?type=waypoint is not a valid layer and can not be
added to the map". If I instead chose an existing gpx-file
on my hard disk, the file gets loaded but without the data
from the GPS device. What should I do?
Be sure you are saving the downloaded file to a directory with
*no spaces* in the path.
This mail was received via Mail-SeCure System.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120306/980d3a68/attachment.html>
