[Qgis-user] GPS-Measure
Giovanni Manghi
giovanni.manghi at faunalia.pt
Tue Mar 6 04:20:03 PST 2012
if the layer you are editing is Postgis you can use a trigger. Have a
look here:
http://ubuntuone.com/3u7v7E6nxg2JaAwXAAGbb8
cheers
-- Giovanni --
On Tue, 2012-03-06 at 08:14 +0100, Starke Holger, Mag. wrote:
> Hello,
> I´m searching fort a possibility to measure areas using
> Live-GPS-Tracked vertices. After adding the feature the Area should be
> displayed and the label should be the measured area. Is it possible to
> combine the GPS-Tracking Tool with the area measuring tool?
> Holger
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-usera
