[Qgis-user] Export map to graphics program
Alex Mandel
tech_dev at wildintellect.com
Tue Mar 6 09:18:14 PST 2012
On 03/06/2012 03:15 AM, Gerhardus Geldenhuis wrote:
> Hi
> I have tried to use the python plugin to export my map as a svg. When it
> worked it was selective about which layers it exported and at the moment it
> crashes. I was wondering if there is another way of exporting an image or
> vector graphic of my map. I want to add final touches to my paper copy map
> in Illustrator and am at the moment considering doing a number of print
> screens and stitching it together.
> Regards
In addition to the SimpleSVG plugin (I assume thats the one you are
trying to use), you can save a pdf or svg from the map composer it just
tends to come out with some extra stuff.
Could you please post more about the error you get? Do you get a message
or the output just isn't what you expect? How many layers, what type?
Does it fail on even simple exports or just complex ones?
Thanks,
Alex
