[Qgis-user] [OSM-talk] QGIS v MapInfo observations
Andreas Neumann
a.neumann at carto.net
Wed Mar 7 06:43:45 PST 2012
agreed.
Comparing a software running in WINE against a native application is
hardly very useful. Also - if the machine has 16 Gig RAM he is probably
running a 64bit version with more RAM in Linux while MapInfo in WINE is
most likely running in 32bit.
Personally, I would not spread such comparisons if they aren't really
sound and fair.
Andreas
On Wed, 7 Mar 2012 12:29:37 +0000, wrote:
> Much as I dislike MapInfo, that comparison is stacked against the
> software. Not only is a very old version being used (He's using
> MapInfo 7.8, apparently released in Sept 2004!!!!
> (http://www.sgsi.com/Prod_Soft_MIPro_78.asp)), on top of which its
> being run in WINE too, which will hardly improve the reliability.
> I don't doubt QGIS would do well against a modern MapInfo deployment,
> but lets not be disingenuous here, comparing a 7 year old product to
> a
> few week old one isn't exactly going to convince naysayers.
> From: Paolo Cavallini
> To: qgis-user
> Date: 07/03/2012 08:48
> Subject: [Qgis-user] [OSM-talk] QGIS v MapInfo observations
> Sent by: qgis-user-bounces at lists.osgeo.org
> http://lists.openstreetmap.org/pipermail/talk/2012-March/062139.html
> [1]
> Interesting IMHO.
> All the best.
> Paolo Cavallini
> See: http://www.faunalia.it/pc
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> This transmission is intended for the named addressee(s) only and
> may
> contain sensitive or protectively marked material up to RESTRICTED
> and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
> Links:
> [1]
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
