[Qgis-user] map does not disply right in composer
Giovanni Manghi
giovanni.manghi at faunalia.pt
Fri Mar 9 12:42:55 PST 2012
On Fri, 2012-03-09 at 12:14 -0500, Jake Maier wrote:
> Now that the different layers all display properly, the shp layer is nearly a km to the east in the composer.
> The layer displays right in the map but not in the composer. How can I fix this?
The layers from the OL plugin are not "supported" in the composer. You
may want to use this virtual earth wms server
http://geoposer.com:443/server/services/ve.xml
and it will work just fine also in the composer.
-- Giovanni --
