[Qgis-user] extents off the scale
Alex Mandel tech_dev at wildintellect.com
Mon Mar 12 20:49:10 PDT 2012
Those coordinates look correct for a State Plane coordinate system
commonly used by counties in the US. If there is no prj file with data,
you can guess the projection by looking up a State Plane reference.
The coordinates should appear as you expect in Lat/Lon if you turn on
projection on the fly and pick Lat/Lon WGS EPSG 4236.
Enjoy,
Alex
On 03/12/2012 08:13 PM, Lee wrote:
> Is QGIS recognizing the Coordinate Reference System correctly?
> all the best,
> Lee Mueller
> Registered Forester #46043
> On Mon, Mar 12, 2012 at 10:47 PM, T. Gray Shaw <tgray at arborartist.com>wrote:
>> I downloaded a shapefile from my local county web GIS and added it to a
>> new project, but the extents are incorrect (1021711,234075 :
>> 1920531,796520)  What is the probable explanation for coordinates being way
>> out of the proper range?
>> Thanks,
>> - Gray
>> T. Gray Shaw
>> ISA Certified Arborist # WE-1037
>> Redway and Berkeley, CA
>> 510 418-3420
>> Skype: tgrayshaw
