[Qgis-user] Saving layer CRS in GML file
Alex Mandel
tech_dev at wildintellect.com
Thu Mar 15 16:16:57 PDT 2012
On 02/28/2012 12:34 AM, Luís de Sousa wrote:
> Dear all,
> I'd like to save the CRS of a layer in its GML file. So far I've been
> trying with the menu Layer> Set CRS of Layer(s); but this way no
> changes are saved to the GML, not even if I save it as a new file. How
> can this be done?
> I'm using version 1.7.4, btw. Thank you and regards,
> Luís
The menu item you're referring to only sets the CRS for the current
session. In the Vector menu under data management there is a Define
Projection tool but I think that might only save .prj files for use with
shapefiles, no idea if it works with GML. If you can try it and report
back that would be useful, as it might be a feature we should consider
adding.
If you try right click on layer-> Save as, then in the dialog pick the
input and output CRS you want and save a new file I believe the new GML
file will contain the CRS.
Thanks,
Alex
PS: Bumping an email thread with no new information is a good way to
annoy subscribers, I suggest refraining from the practice in the future.
