[Qgis-user] Re: Saving layer CRS in GML file
Luís de Sousa luis.a.de.sousa at gmail.com
Fri Mar 16 04:03:25 PDT 2012
Hello Alex,
As you can see the original message was posted on the 28th of April, 2 weeks
and a half ago. It contains a fairly objective question that is complete in
itself. Whenever this message fell to the 2nd or 3rd page in the message
list the number of views stopped increasing. I believe I had two options:
repost or bump; on other fora repost is usually taken as unpolite, beyond,
of course, the replication of threads. If you have a further alternative to
suggest in this case I will gladly use it in this forum henceforth.
Regarding the issue itself, the "Define current projection" tool doesn't
appear to be working; it always returns the error message "Output spatial
reference system is not valid" no matter what output CRS I try to define.
I'll try to gather more information and post a specific message for this
subject.
A GML file without CRS definitions is useless for most purposes. If indeed
QGis doesn't have yet this functionality, then I believe its inclusion
should be considered for a following release in a not to distant future.
Regards,
Luís
Alex Mandel-2 wrote
> The menu item you're referring to only sets the CRS for the current
> session. In the Vector menu under data management there is a Define
> Projection tool but I think that might only save .prj files for use with
> shapefiles, no idea if it works with GML. If you can try it and report
> back that would be useful, as it might be a feature we should consider
> adding.
> If you try right click on layer-> Save as, then in the dialog pick the
> input and output CRS you want and save a new file I believe the new GML
> file will contain the CRS.
> Thanks,
> Alex
> PS: Bumping an email thread with no new information is a good way to
> annoy subscribers, I suggest refraining from the practice in the future.
> Qgis-user mailing list
> Qgis-user at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/Saving-layer-CRS-in-GML-file-tp4520824p4624798.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
