[Qgis-user] Re: Saving layer CRS in GML file
Alex Mandel
tech_dev at wildintellect.com
Fri Mar 16 10:07:59 PDT 2012
Ah, a weird aspect of the fact that the "Forum" is actually a front-end
to a mailing list. Many of us actually only use the mailing list and
many only the forum so it leads to some interesting differences. I
didn't realize your original email was from so long ago.
Now as Giovanni said, look for an existing ticket and if you don't find
one file a new one so the developers can look into it more. Please be
prepared to attach a sample file for testing.
http://hub.qgis.org/projects/quantum-gis/issues
Thanks,
Alex
On 03/16/2012 04:03 AM, Luís de Sousa wrote:
> Hello Alex,
> As you can see the original message was posted on the 28th of April, 2 weeks
> and a half ago. It contains a fairly objective question that is complete in
> itself. Whenever this message fell to the 2nd or 3rd page in the message
> list the number of views stopped increasing. I believe I had two options:
> repost or bump; on other fora repost is usually taken as unpolite, beyond,
> of course, the replication of threads. If you have a further alternative to
> suggest in this case I will gladly use it in this forum henceforth.
> Regarding the issue itself, the "Define current projection" tool doesn't
> appear to be working; it always returns the error message "Output spatial
> reference system is not valid" no matter what output CRS I try to define.
> I'll try to gather more information and post a specific message for this
> subject.
> A GML file without CRS definitions is useless for most purposes. If indeed
> QGis doesn't have yet this functionality, then I believe its inclusion
> should be considered for a following release in a not to distant future.
> Regards,
> Luís
> Alex Mandel-2 wrote
>> The menu item you're referring to only sets the CRS for the current
>> session. In the Vector menu under data management there is a Define
>> Projection tool but I think that might only save .prj files for use with
>> shapefiles, no idea if it works with GML. If you can try it and report
>> back that would be useful, as it might be a feature we should consider
>> adding.
>> If you try right click on layer-> Save as, then in the dialog pick the
>> input and output CRS you want and save a new file I believe the new GML
>> file will contain the CRS.
>> Thanks,
>> Alex
>> PS: Bumping an email thread with no new information is a good way to
>> annoy subscribers, I suggest refraining from the practice in the future.
>> Qgis-user mailing list
>> Qgis-user at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
