[Qgis-user] Re: Spatialite data portability
magerlin MAP at ramboll.dk
Sat Mar 17 06:02:27 PDT 2012
Walter Ludwick wrote
> ... because having certain attributes that are best defined in QGIS (e.g.
> perimeter, area, etc.)- i will still be working with that data in
> spreadsheets on a much more dynamic basis.
Hi Walter
You migth already know this, but in Qgis in the layer properties Feilds pane
you can set up different Edit Widgets for the coulmns in your layer which
can help you if you should choose to interact with your data directly in
Qgis.
For example you can enter dates by choosing from a calender, you can browse
for file names, you can use check boxes or you can choose between predifined
values or ranges - 12 different Edit Widgets are available.
Perhaps this will be more convenient than the spreadsheet solution?
Regards Morten
Qgis 1.7.4 Stand alone installer in Win7 64 bit
View this message in context: http://osgeo-org.1560.n6.nabble.com/Spatialite-data-portability-tp4621032p4627868.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
