[Qgis-user] Re: QGIS + Inkscape
    G. Allegri
    giohappy at gmail.com
    Mon Mar 19 01:04:24 PDT 2012
I agree with Jukka.
Working to a lower level of binding (through GDAL/OGR) would let other foss
software leavarage the improvements.
I don't know Inkscape very much, but I've tried to import the latter
example from Jukka (the multilayer PDF) and it keeps the layers correctly.
Working on the GDAL level is probably harder then doing the work on the
Python level directly between Qgis and Inkscape, but I feel it would be far
most used and useful to improve the GDAL PDF support...
giovanni
2012/3/19 Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>
> Brylie Oxley <brylie at ...> writes:
> > Hello,
> > My name is Brylie Oxley. I am a student at Sierra College in Nevada
> > City, CA. I would like to apply for the GSoC program.
> > I have been studying GIS at Sierra College, where the courses focus on
> > proprietary tools. For libre GIS tools to be viable options, we need
> > high quality cartographic tools. This is where I see Inkscape as an
> > EXCELLENT candidate.
> > I would like to make an extension for QGIS and/or Inkscape that would
> > enable us to send data from QGIS directly to Inkscape. It would also be
> > nice to be able to have Inkscape leverage the QGIS API to import
> > data/layers into a cartographic project.
> > I am glad to get any feedback regarding users' experiences sharing data
> > between these two programs. I would also like to know what some of the
> > components are that I can leverage to create a bridging
> > extension/improved cartographic interface for QGIS.
> > Thank you for your time and consideration,
> > Brylie Oxley
> There is heavy work going on with GDAL PDF driver
> http://gdal.org/frmt_pdf.html
> Mapserver can already make georeferenced PDF files like this with the trunk
> version of GDAL http://latuviitta.org/documents/Lahti_geospat.pdf
> Reading the geospatial info of that certain PDF needs TerraGo Toolbar
> which is
> an add-on to Adobe Acrobat reader. Here is another PDF output example
> http://latuviitta.org/documents/raitiovaunulinjat.pdf
> It is made with OpenJUMP derivative SkyJUMP and it demostrates using vector
> layers on to of a raster layer (tram lines in this case). User can toggle
> the
> layer visibility at least with Adobe Acrobat Reader. I am not sure if GDAL
> can
> do such layered output yet. However, I have a feeling that GDAL may soon
> be able
> to support direct conversion of raster files with OGR vector file overlays
> into
> layered and georeferenced PDF files. See recent PDF commits by Evan
> Rouault at
> http://trac.osgeo.org/gdal/timeline
> Perhaps that work will help you with the QGIS to Inkcape work flow. At
> least it
> might be good to study what could be done by feeding GDAL from QGIS before
> dublicating those functionalities into QGIS.
> -Jukka Rahkonen-
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120319/0c36ec18/attachment.html>
