[Qgis-user] Copy a raster
Tim Sutton
lists at linfiniti.com
Thu Mar 22 04:57:12 PDT 2012
Hi
On Thu, Mar 22, 2012 at 4:33 AM, David Fawcett <david.fawcett at gmail.com> wrote:
> Try right-clicking on the layer in QGIS and selecting 'Save As...'
> You have the option of saving the data in different file formats too.
This currently only works for vector layers.
> David.
> On Wed, Mar 21, 2012 at 9:17 PM, john.polo <jpolo at mail.usf.edu> wrote:
>> QGIS Users,
>> New QGIS user here, as well as a novice at GIS, with what is probably a
>> basic question. If I want to copy a raster (.tif), should I just Cntl-C the
>> file in the folder and paste and rename the copied file back into the
>> folder? In ArcGIS I'd export the data and make all the copies I want. (Not
>> griping against QGIS, just trying to give a better indication of what I
>> intended to do) I looked in the edit menu and couldn't find an export or
>> copy function. The edit toggle doesn't activate the layer for me to copy
>> like I would a polygon. I checked the raster menu and wasn't sure which
>> function would make a copy of the raster.
First ensure the 'GdalTools' plugin is enabled in your copy of QGIS
(Plugins Menu -> Manage Plugins -> Tick Gdal Tools).
Then to copy a raster do: Raster Menu -> Conversion -> Translate
>From the translate dialog, you can output can secify various output
options, including the desired format and then write the new dataset
out to disk.
Hope that helps!
Regards
Tim
>> John Polo
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
