[Qgis-user] QGIS user map
Tim Sutton
lists at linfiniti.com
Thu Mar 22 05:00:55 PDT 2012
Hi
On Fri, Feb 24, 2012 at 12:58 AM, Ramon Andiñach <custard at westnet.com.au> wrote:
> I'm quite sure this is going to sound odd, but here goes.
> I'd be happy to be a dot on the map, but while I can be readily identified from the dot (and my dot would be clearly visible on the global-scale map) I'm not interested. Sorry.
> -ramon.
Your email address is not published (it is only used to allow you to
update your details later). You can use any name you like and put e.g.
the center of the city you live in if you don't want a knock on the
door from a government agent for being a subversive FOSSGIS user :-)
Regards
Tim
> On 24/02/2012, at 03:02 , Paolo Cavallini wrote:
>> Hi all.
>> I'm trying to understand the distribution of QGIS users, in relation to population density etc. Please add yourself to the map:
>> http://planet.qgis.org/community-map/
>> and let your local communities do the same.
>> All the best, and thanks.
>> Paolo Cavallini
>> See: http://www.faunalia.it/pc
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
