[Qgis-user] Re: ecw problems
G. Allegri
giohappy at gmail.com
Fri Mar 23 00:44:57 PDT 2012
You can set the DLLs to load defining PATH (and others) environmental
variables, but you're only allowed to use the same GDAL used to compile
QGis. So, if QGis is using GDAL 1.9, it cannot load and se GDAL 1.8 (weel,
if it would happen would be casuality!)
giovanni
2012/3/23 pieri70 <pietro.rossin at gmail.com>
> Hi Andre
> my problem is that GDAL is used by QGis and both these programs are
> installed trough Osgeo4W setup.
> So, how can I make qgis installed that way use GDAL installed as
> standalone?
> Doesn't it collide with the one given by Osgeo4W, that is installed too?
> Thanks
> Pietro
> http://osgeo-org.1560.n6.nabble.com/ecw-problems-tp4126237p4647685.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120323/98987185/attachment.html>
