[Qgis-user] contours
T. Gray Shaw
tgray at arborartist.com
Sun Mar 25 22:33:45 PDT 2012
You should see the Raster -> Extraction -> Contour tool if you have GDAL tools turned on in the Plugins menu.
- Gray
On Mar 25, 2012, at 8:10 PM, john raskulinecz wrote:
> Hello Giovani,
> Thanks for your suggestion regarding contouring delim txt files. When I click Raster on the main toolbar that has " File Edit View, etc." it only shows raster calculator. I tried that but it said it was doing base template building.
> So I guess I'm back to square one. Might there be a quick way to convert the dltxt file to a vector file and contour that way?
> Regards' J.R.
> Qgis-user mailing list
On Mar 25, 2012, at 3:53 PM, Giovanni Manghi wrote:
> use the raster -> extraction -> contour tool. Be sure to have the "gdal
> tools" plugin active (it is installed by default).
> cheers
> -- Giovanni --
> On Sun, 2012-03-25 at 15:46 -0700, john raskulinecz wrote:
>> Micha, thanks
>> I downloaded QGISOSGEOW-1.7.4D211BV.16 and its up and running and have
>> looked in Plugins>manage plugins> but can not find contours. I have
>> right clicked on the layer and looked for contour, then went to
>> properties and could not find a way. It seems to me that it wasn't
>> this hard before. I'll try to re download and scour the user guide. I
>> also tried the links you sent. One went into a "nested loop" the other
>> came up so I'll be looking at that.
>> Thanks again,
>> J.R.
T. Gray Shaw
ISA Certified Arborist # WE-1037
Redway and Berkeley, CA
510 418-3420
Skype: tgrayshaw
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120325/68f458f9/attachment.html>
