[Qgis-user] Dissolve and sum of merged attributes?
Dr_Strangelove
fredrik.floren at teliasonera.com
Sun Mar 25 23:44:03 PDT 2012
In a layer I have, e.g., a map of a number of areas of a country. Each area
has a row in the attribute table and a associated polygon. Each area also
has a number of fields with numerical values. Is there a way to merge the
areas based on a field value and sum the respective values of another field?
Like dissolve but instead just replacing fields of the merged polygons, I
would like to sum them up. I guess this operation must be applicable in a
number of cases, maybe when summing up inhabitants in different areas but
with the same zip code. However, I can't find a way to do it.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Dissolve-and-sum-of-merged-attributes-tp4655757p4655757.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
