[Qgis-user] SEXTANTE for QGIS has been released
Carlos Grohmann carlos.grohmann at gmail.com
Sat Mar 31 10:53:45 PDT 2012
Found it!
thanks
Prof. Carlos Henrique Grohmann
Institute of Geosciences - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com (http://carlosgrohmann.com/)
________________
Can’t stop the signal.
Sent with Sparrow (http://www.sparrowmailapp.com/?sig)
On Saturday, 31 March 2012 at 14:39, Gary Sherman wrote:
> On Mar 31, 2012, at 9:35 AM, Carlos Grohmann wrote:
> > Hi, I couldn't find the sextant plugin in qgis 1.7 on mac os x. is it on http://mapserver.sk/~wonder/qgis/plugins-sandbox.xml? this repo is giving connection errors.
> > best
> It is in the new plugin repository (http://plugins.qgis.org/plugins/plugins.xml). You must have enabled viewing of experimental plugins in the Options tab of the plugin installer in order to see it.
> > Carlos
> > ________________
> > Sent with Sparrow
> > On Friday, 30 March 2012 at 18:19, Victor Olaya wrote:
> > > > One remark / request on concerning GRASS; as the GRASS algorithms are
> > > > already available through the GRASS toolbox, the main thing for me would be
> > > > to enable the use of GRASS raster and vector layers in all the SAGA (and
> > > > other) modules. I assume this will be part of the working version you
> > > > mention?
> > > Well, the idea is just the opposite: to use any raster or vector layer
> > > in GRASS, directly from QGIS. "Any" in this context means any "normal"
> > > file-based layer. What you propose is just the opposite: to use GRASS
> > > layers in other apps. This is something I plan to work on later. As I
> > > mentioned in the release note, now SEXTANTE handles those "normal"
> > > layers, but not others like layers from remote services, from DB
> > > connections or "special" layers like GRASS ones. I hope to give
> > > support for all that as well, so any layer than can be loaded into
> > > QGIS can be passed to an external application transparently, with
> > > SEXTANTE doing the necessary work of conversion or whatever is needed.
> > > However, I will wait until this first version works fine before
> > > starting that.
> > > Regards
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org (mailto:Qgis-user at lists.osgeo.org)
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> -gary
> Gary Sherman
> GeoApt LLC
> http://geoapt.com
> Founder, Quantum GIS
> Chair, QGIS PSC
> Book:
> http://geospatialdesktop.com
> "We work virtually everywhere"
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120331/e0a0fcdf/attachment.html>
