[Qgis-user] Scale bar and area calculation issues
Tony Bigbee tony.bigbee at gmail.com
Sat Mar 31 16:14:32 PDT 2012
Thanks, Micha.  Layer: Save As... was what I needed to know.
Even when the project is a different projection, when I select Project
CRS, "WGS 84" still displays in the text box instead of the project
CRS.  If I manually browse to it, I can select an apply the CRS I
want.  Don't know if that is a bug.
Thanks for the assistance.
2012/3/31 Micha Silver <micha at arava.co.il>:
> So what you are doing here is forcing QGIS to *wrongly* assume that the
> geojson layer is in EPSG:3665. The original layer was, and should stay, as
> WGS84, Lon/Lat. If you want that layer to be re-projected to another
> coordinate system, use the Save As... , choose i.e. EPSG 3665, and you'll
> create a new layer, projected in this new CRS.
File:  Save Project As:  doesn't give me any CRS options, just a file name.
So I save it, restart QGIS and nothing has changed.
I think that's why I'm finding the reprojection process
counterintuitive.   Changing the project settings to a different CRS
doesn't actually change the layers, and I can't see any way in Save
Project As or other to transform/reproject.
