[Qgis-user] OpenLayers plugin crash, very slow startup
Giovanni Manghi
giovanni.manghi at faunalia.pt
Wed May 2 04:17:01 PDT 2012
Hi
> Can anyone confirm this behaviour of 1.7.4 and last master on Windows
> XP? _Very_ slow startup, up to 1 minute... It shows splash screen, and
> then nothing happens for about a minute, and then it loads and works
> normally.
I have seen this many times on other people (Windows) computer. Usually
they have a lot of plugins installed they don't use. Disabling them is
usually enough to make qgis start much more faster.
> No unexpected behaviour or unresponsiveness detected so far, after the
> initial startup, except when using OpenLayers plugin that still
> crashes QGIS. Especially annoying when opening older projects that
> already have OL layers in them, it just crashes when you try to open
did you updated to the latest OL plugin version? anyway the plugin has
its own tracker on hub.qgis.org so if you think you found an issue
please file a ticket there.
cheers
-- Giovanni --
