[Qgis-user] Pan-Map command problem
Christian Hickel
hickel at geod.tu-darmstadt.de
Wed May 2 04:33:45 PDT 2012
Hello,
I have a problem with the Pan Command what nobody seems to have in the hole
world. :-) Ones in a while the command "Pan map" hangs. I can't select
another command like Zoom In Or Identify Feature. The Pan-command persists
and even without "holding the left mouse key" the map will be paned.
The only way is to solve the problem is restarting QGIS.
Thanks for any hint
Christian
