[Qgis-user] qgis on linuxmint?
Alex Mandel tech_dev at wildintellect.com
Wed May 2 12:43:26 PDT 2012
OSGeo Live maintains an svn repo:
http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/
The bin folder has the scripts, other folders have supporting files.
See http://wiki.osgeo.org/wiki/Live_GIS_Disc for more details about the
build process.
Enjoy,
Alex
On 05/02/2012 12:36 PM, Hugo wrote:
> Hi Alex,
> Just out of curiosity where would those scripts be downloadable??? I've
> been trying to find them but didn't get them.
> Cheers,
> Hugo
> On Wed, May 2, 2012 at 6:37 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>> In fact it's been done for you already
>> http://live.osgeo.org
>> The whole stack installed and setup together on a linux box. FYI the
>> scripts used to do all the installing are available if you want to pick
>> and choose what to install and it's all based on Ubunutu/Xubuntu so any
>> variant of those will work.
>> Enjoy,
>> Alex
>> On 05/01/2012 03:36 AM, António M. Rodrigues wrote:
>>> Hi all,
>>> A quick question concerning QGIS (and other software - GRASS, R ...) on
>>> Linux.
>>> I have a MAC but at work I am thinking a getting a new machine, running
>>> Linux. After browsing the net for optional distributions, I came across
>>> ArchLinux. It immediately caught my attention with the phrase "A simple,
>>> lightweight distribution".
>>> The question is: the fact that it is "so lightweight", does it mean it
>> will
>>> be painstakingly hard to get every bits together in order to have all
>>> frameworks, all dependencies, etc, working in order to have a fully
>> working
>>> GIS workstation (QGIS, GRASS, R, ...)?
>>> Thanks.
>>> Regards,
>>> António
>>> On Tue, 1 May 2012 12:06:27 +0200, Agustin Lobo wrote:
>>>> Lee,
>>>> 2012/4/29 Lee Hachadoorian <Lee.Hachadoorian+L at gmail.com>:
>>>>> Agustin,
>>>>> I suppose it depends on what you don't like about Ubuntu. I also use
>>> 10.04,
>>>>> and am planning on upgrading to 12.04 but keeping the GNOME desktop
>>>>> environment.
>>>> Ii think you'll be disapointed...
>>>> But if you're looking to get away from Ubuntu, what about the
>>>>> OSGeo-Live distro? It's based on Xubuntu and comes pre-loaded with QGIS
>>> and
>>>>> a bunch of other GIS software, as well as other goodies like R. I've
>>> used it
>>>>> occasionally to test some of the applications that aren't in the
>> regular
>>>>> Ubuntu repos.
>>>> That's a good way to get introduced to the different OSGeo applications,
>>> but
>>>> does not solve my problem.
>>>> Thanks!
>>>> Agus
>>>>> Best,
>>>>> --Lee
>>>>> On Sat, Apr 28, 2012 at 3:54 PM, Werner Macho <werner.macho at gmail.com>
>>>>> wrote:
>>> Hi Agus!
>>> I am using LMDE (Linux Mint Debian Edition) since more than a year now
>>> and I am very satisfied with it.
>>> Before I used Gentoo Linux (which also worked fine) but Gentoo was too
>>> much compiling time for me .. So I decided to switch back to something I
>>> use on servers since a long long time .. Good old debian .. But as plain
>>> debian is on one side rock solid - the other side is .. you always are a
>>> bit outdated .. Thats the reason why I choose the rolling release LMDE
>>> based on debian testing ..
>>> I never had a real problem using it and can recommend it for everything
>>> you want to do..
>>> So on your side - if you want to switch away from ubuntu .. don't take
>>> linuxmint - it is based on ubuntu anyway (ok they try to not use unity -
>>> but the base is still the same).. just take LMDE .. debian, stable, with
>>> newer software from mint..
>>> (I don't want to start a distribution flamewar here - it's just that I
>>> am really satisfied with it)
>>> just my 2¢
>>> kind regards
>>> Werner
